Let us first understand about the AWS Batch, before moving on to AWS Batch plug-in and how it is benefits to our workload automation users.
The AWS Batch is available on Automation Hub, download it to empower your Workload Automation environment.
AWS Batch
AWS Batch enables developers, scientists, and engineers to run hundreds of thousands of batch computing jobs easily and efficiently on AWS. AWS Batch dynamically provisions the optimal quantity and type of compute resources (e.g., CPU or memory optimized instances) based on the volume and specific resource requirements of the batch jobs submitted. With AWS Batch, there is no need to install and manage batch computing software or server clusters that you use to run your jobs, allowing you to focus on analysing results and solving problems. AWS Batch plans, schedules, and executes your batch computing workloads across the full range of AWS compute services and features.
Now let us see how easy it is to start and monitor AWS Batch job.
Create a new job and select “AWS Batch” in the Cloud section.
AWS Batch
Figure 1: Job Definition page
Connection
First, establish a connection to the AWS server by entering the required details.
Then, you can test the connection to AWS server by clicking on Test Connection.
AWS Batch
Figure 2: Connection page
AWS Batch
Figure 3: Connection page > Test Connection
Action
After having successfully tested the connection, you can go to the Action tab and specify the details about the job queue and define what actions you want to perform.
  • Job Name: Specify the name of the job, it must be unique among the running jobs.
  • Job Queue: Jobs are submitted to a job queue where they reside until they can be scheduled to run in a compute environment. If you do not have any job queue, create one. You can choose job queue with scheduling priority or without scheduling priority.
  • Job Definition: It specifies how the jobs should run. You can create/use (if exist) single node job definition or multiple job definition. Select any one of the job definition.
  • Share identifier: Use any text as share identifier if you use only job queue with scheduling priority. Do not enter any text on share identifier field if you use job queue without scheduling priority.
AWS Batch
Figure 4: Action page
Job Configurations:
VCPUs: Choose the number of vCPUs that your compute environment should launch with. As your job queue demand increases, AWS Batch can increase the desired number of vCPUs in your compute environment. The minimum vcpu you can use is 1.
Memory: Specify the memory hard limit (in MiB) present to the container.
GPUs: There are different types of GPU available, specify the GPUs value. This is an optional field.
AWS Batch
Figure 5: Action page > Job Configurations
Command:
User can use different commands for AWS batch to display in job logs for Ex:
User can write “echo” in first field
Click on + button
Then write any text like “Job Success”
This message should display in job logs after job success
Environment Variable:
AWS Batch automatically sets specific environment variables in container jobs. These environment variables provide introspection for the containers inside jobs, and you can use the values of these variables in the logic of your applications. All variables that are set by AWS Batch begin with the prefix, AWS_BATCH_.
For Ex:
Name: AWS_BATCH_JQ_NAME Value :Job queue name
AWS Batch
Figure 6: Action page > Environment
Parameters:
When you submit a job, you can specify parameters that should replace the placeholders or override the default job definition parameters. Parameters in job submission requests take precedence over the defaults in a job definition.
For Ex:
Name: command Value: [“abc” , “data”]
AWS Batch
Figure 7: Action page > Parameters
Submitting your job
Submit your job into the current plan. You can add your job to the job stream that automates your business process flow. Select the action menu in the top-left corner of the job definition panel and click on Submit Job into Current Plan. A confirmation message is displayed, and you can switch to the Monitoring view to see what is going on.
AWS Batch
Figure 8: Submitting job
Monitor Page:
AWS Batch
Figure 9: Monitor page
If Job is success in backend AWS Batch then status should be changed to successful.
AWS Batch
Figure 10: Monitor page contd.
You can cancel the running job by clicking kill option.
AWS Batch
Figure 11: Monitor page contd.
Job Log Details :
AWS Batch
AWS Batch
Figure 11: Job log
  |  May 12, 2022
Enhancing observability with AI in HCL Workload Automation
HCL has introduced a new set of features to HCL Workload Automation Platform (HWA) 10, with IT and business automation with streamlined modeling and advanced AI.
HCLSoftware | August 5, 2022
Trigger UiPath jobs with HCL Workload Automation
The UiPath plug-in is available on Automation Hub, and it helps you trigger and monitor all the UiPath processes directly from the Dynamic Workload Console.
AEX
