Improving your team’s collaboration and productivity is a sure way to accelerate your company’s path to quality assurance.
And now you can with HCL’s new OneTest suite version 10. This latest installment speeds up testing, while cutting down the need to maintain an expensive test infrastructure, all while using a new friendly user experience.
The new version also boasts the HCL OneTest Server — a fully-contained, secure by design, server, which enables users to bring together testing from across the OneTest products.
“Our HCL OneTest Server brings together test data, test environments and test execution into a single, easy-to-use dashboard for testers and non-testers,” said Chris Haggan, HCL Product Manager for Functional and Performance Test Automation.
The OneTest Version 10 also introduces new capabilities such as:a
  • New dataset technology
  • Native GIT integration across the OneTest portfolio
  • JMeter integration for performance testers
Learn more about this exciting launch here.
About HCL OneTest
HCL OneTest provides software testing tools to support a DevOps approach: API testing, functional testing, UI testing, performance testing and service virtualization.
It helps you automate and run tests earlier and more frequently to discover errors sooner — when they are less costly to fix. HCL also provides a bundled offering under a new consumption model that changes the way you can use and deploy DevOps software.
The new offering helps simplify your planning for adoption and growth of critical DevOps products.
Comment wrap
  |  April 21, 2023
HCL OneTest Delivers New Software Features
HCLSoftware is pleased to announce a new version of software testing tool, HCL OneTest 10.5.2. Check out what's new!
  |  February 14, 2023
API Testing Kubernetes: Transparent Remoting Using HCL OneTest
Testing in a cloud and containerized world is often very difficult. One of the painful tasks that testers have to face is that once the containers are deployed, some of their APIs might remain accessible but others — the internal ones — are not reachable anymore.
  |  January 4, 2023
Why You Need Continuous Testing and How to Go About Choosing the Right Partner
What are some key factors to consider for a successful continuous testing strategy? How do you go about choosing the right continuous testing vendor who can truly be a partner and help you succeed in your goals?
