RTist models are stored in XML files (.emx and .efx). If you have ever opened such a file in a text editor you have probably noticed that code snippets stored in the model can be quite difficult to read due to the encoding of certain characters that is mandated by XML. Here is an example:
code_snippet_in_xml
Some code snippets are stored as attributes in XML and they can look even worse, since newlines also will be encoded so that the whole code snippet appears on a single line:
code_snippet_in_xml2
Starting with RTist 11.0 2020.33 it’s now possible to set a preference so that code snippets will be saved in CDATA sections in the XML file. Thereby the code does not need to be escaped which greatly improves its readability. The preference is called Use CDATA when saving model files and is located on the Modeling preference page. In addition to code snippets, it also affects how documentation texts are stored.
CDATA_preference
After setting this preference, the code snippets in the examples above will look like this:
code_snippet_in_xml_cdata
code_snippet_in_xml2_cdata
Note that older versions of RTist can still read model files that use CDATA. In that sense this feature is backwards compatible. Note, however, that if you edit and save the model in such an old tool version the code snippets will once again be stored without usage of CDATA.
If you decide to start using CDATA in your model files it can be a bit tedious to manually re-save all files in the workspace to use the new format. To simplify you can run a model fixup which will automatically convert all your model files to use CDATA.
model_fixup_cdata
Watch this video for more information.
Video image
  |  July 23, 2020
Introducing Design Room ONE Version 2.1
The latest Sprint 2020.26 bring us a new version 2.1 of Design Room ONE available for HCL RTist users.
  |  February 8, 2021
New RTist Deliverables Now Available for Download
HCL RTist 11.0 2021.04 and experimental version 11.1 2021.04 two deliveries are available for download. Feel free to reach out to the development team.
  |  December 15, 2020
RTist 11 Version 2020.50 is Now Available
The new version of RTist 11 - 2020.50 has improvements and can now move transitions from one state to another using drag-and-drop in Project Explorer.
