• Overview
  • Documentation
  • Version history
Description
Project Management flow allows users to manage tasks and subtasks to execute a project.
Quick Info
Product icon
Product
Plugin type icon
Type
plugin
Compatibility icon
Compatibility
HCL Compass; IBM ClearQuest
created by icon
Created by
HCL Software
Published Date
Last Updated
Overview
Project Management flow allows users to manage tasks and subtasks to execute a project and includes the following features:
  • Alert Management
  • Application Items
  • Approval Management
  • Boards
  • Charts
  • Notifications
  • Queries
  • User Management
Steps
On Windows:
  1. Create a repository and application.
    1. Create a repository based on a blank schema using the Maintenance Tool by clicking Select Schema Repository from within the Maintenance Tool.
    2. Click New and provide a name for the schema.
    3. Select a Database Vendor and then click Next.
    4. On the Data Code Page screen, select Next.
    5. Uncheck Create Sample DB.
    6. Select any schema to use and provide a database name. The default value is SAMPL.
    7. Click Next.
    8. Specify DB Vendor for user database.
    9. Click Finish.
  2. Import the Project Management Schema.
    1. Import the schema text file to the newly created repository using the following command.
    2. Launch the command prompt with administrative privileges.
    3. Download the schema and copy to the Compass or ClearQuest installation directory.
    4. Run the following command:
      cqload importschema [-dbset dbset ] -installpackages loginID password ProjectManagement.schema
  3. Create an application from the Project Management Schema.
    1. Launch the Eclipse Designer or the Native designer.
    2. Select the Repository that you created in step 1. Right click and then select Connect.
    3. Login to the repository with the user name and password. By default, the user name is admin and the password is left blank.
    4. Under the Root View menu, select Compass Database Administration.
    5. The view appears in one of the tiles within the Eclipse designer.
    6. Right click the view and select Create Database.
    7. Specify the logical name of the database. For example, you may use TEST or SAMPL.
    8. Select the database (Production) vendor and leave the other defaults in place and select Next.
    9. Specify the DB properties required and select Next.
    10. Leave the default values in place and select Next.
    11. In the Initial Schema Revision Screen, select Requirements and the latest version, and then select Finish.
  4. Accessing the Application
    1. Go to the Compass or ClearQuest host URL.
    2. Select the application that you created and log in.
Usage
Settings
Related Plugins
